Results 1 to 2 of 2
Thread: Is A1200.02 enuf power for 1 PPI Pro12????
  1. #1
    Points: 8,931, Level: 22
    Level completed: 61%, Points required for next Level: 319
    Overall activity: 0%
    Achievements:
    Veteran5000 Experience Points
    Join Date
    Mar 2000
    Location
    Malaysia
    Posts
    39
    Points
    8,931
    Level
    22
    Post
    HI Guys!!
    I really need some advice from you guys. I have 1 unit of PPI Pro 12 woofer and 1 unit of PPI A1200.2 to power my bass. Currently, the woofer is being set in a Seal Box enclosure (1.25 cubic ft), but it just sounds good but NOT LOUD N GOOD!!
    So can someone be real nice, if they can advise me on what enclosure and size should I design my box if I wanna go LOUD??? And how should i wire my amp to maximize its power!
    BTW, I am not located in USA...I am in Singapore. I really need some expertise here!! And I really wanna kick some loudass with my Single 12 and PPI A1200.02!!!
    Need help!
    Kevin
    Kevin
  2. #2
    Points: 18,566, Level: 33
    Level completed: 2%, Points required for next Level: 1,084
    Achievements:
    Veteran10000 Experience Points
    Join Date
    Feb 2000
    Location
    Borden, Saskatchewan. Canada
    Posts
    3,558
    Points
    18,566
    Level
    33
    Post
    What you want to do is put that sub in 4.25 cubic feet,with a 6" diameter port that is 10" long. It will take some creativity to fit the port in,but when you are finished it will hammer hard and low. Remember that the speaker is not designed for the type of abuse you will give it, so learn what to play and know the limits of the sub/box.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
