Results 1 to 4 of 4
Thread: 600 Watt Amp for my 12" Juggernaut?
  1. #1
    Points: 11,317, Level: 25
    Level completed: 52%, Points required for next Level: 433
    Overall activity: 0%
    Achievements:
    Veteran10000 Experience Points
    Join Date
    Dec 1999
    Location
    WINDY CITY (Due to extremely loud bass, out of one Grave Digger)
    Posts
    1,012
    Points
    11,317
    Level
    25
    Cool
    Please, please, please help me someone. I need to find an amp rated at 600 watts @ around .75 ohms. Any suggestions?
    1 MMAT D100HC
    1 Juggernaut 12''
    1 Stock Honda Accord
    145.6dbs (Just breakin it in!)
    AND THAT'S NOT MY FINAL ANSWER!
    <A HREF=http://www.termpro.com/asp/competitorstats.asp?Competitor_ID=9611 Target="_new"> <A>
  2. #2
    Points: 12,612, Level: 26
    Level completed: 96%, Points required for next Level: 38
    Achievements:
    Join Date
    Sep 1999
    Location
    state college, pa
    Posts
    1,927
    Points
    12,612
    Level
    26
    Post
    a mmats mini d would work. Or an audiobahn class d, or an autotek.
    Attention Nashville, we have incoming!
    The SHOCKERS have landed!
  3. #3
    Points: 9,093, Level: 22
    Level completed: 81%, Points required for next Level: 157
    Achievements:
    Veteran5000 Experience Points
    Join Date
    Mar 2000
    Location
    ha! they got you!
    Posts
    231
    Points
    9,093
    Level
    22
    Talking
    go wit mini d or a usamp.
    2 12" Polk dB's
    Cadence A2000+
    Pannysonic df88
    and lotsa bass
  4. #4
    Points: 9,499, Level: 23
    Level completed: 32%, Points required for next Level: 551
    Achievements:
    Join Date
    Feb 2000
    Location
    Kalispell,MT,USA...
    Posts
    231
    Points
    9,499
    Level
    23
    Post
    Kicker xs 50 or a class D dx 700 DX amps operate at 70-80% efficiency across the entire power range. This compares to standard amps which may typically operate at around 50-60% efficiency at full power - and an even lower 30% at one-fourth power.Other features include a Module Docking Port loaded with KICKER's popular SWX 24dB/octave active electronic subwoofer crossover module, a switchable subsonic filter with ultra-steep 24dB/octave cutoff at 25Hz which allows the user to eliminate power-robbing inaudible frequencies, and a remote gain controller for setting the amp's gain from the dash without changing the balance of the rest of your system.
    Kicker only...18 WORLD CHAMPION'S...won 75% of all Pro sound quality championships!won 42.8% of all sound quality championships available!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
