Results 1 to 9 of 9
Thread: amp problems
  1. #1
    Points: 9,248, Level: 22
    Level completed: 99%, Points required for next Level: 2
    Overall activity: 0%
    Achievements:
    Veteran5000 Experience Points
    Join Date
    Sep 1999
    Location
    cumming, georgia, USA
    Posts
    31
    Points
    9,248
    Level
    22
    Unhappy
    hey guys,
    update on my cold weather starts noise problem. i messed with the wiring, and found that if i switched the speakers (left->right right->left) the noise moves from the right side speakers to the left (it's a nasty interference noise) but if i switch the rcas it stays put, so i'm guessing i've narrowed the problem the amp itself (rf punch 60ix running fanatic components). i was hoping the problem was the crossovers (mounted in the door panels, was hoping they were just too cold) but it looks as if it's the amp. it goes away when it warms up, but that takes alot of time cuz it's so cold and when i'm out of my truck for 15 minutes it comes back. any ideas or should i just start shopping for a new amp?
    thanks in advance,
    ~erik
  2. #2
    Points: 10,326, Level: 24
    Level completed: 35%, Points required for next Level: 524
    Achievements:
    Veteran10000 Experience Points
    Join Date
    May 1999
    Location
    kankakee,IL
    Posts
    89
    Points
    10,326
    Level
    24
    Post
    take it in to be fixed sounds like it might be a cold solder joint its about all you can do or get a new one
    There is no "best" only preferances.
  3. #3
    Points: 15,556, Level: 30
    Level completed: 11%, Points required for next Level: 894
    Achievements:
    Join Date
    Mar 2000
    Location
    Abbotsford, BC, Canada
    Posts
    3,685
    Points
    15,556
    Level
    30
    Cool
    Bingo, you have a cold solder joint somewhere. Simple fix!
    And that's the bottom line, cuz:
    LORD DUKK SAYS SO!
    The Big Show
    The Dukk says: Know your bass: PORT your damn box!!
    Have HoleSaw, Will Travel!
  4. #4
    Achievements:
    Join Date
    Sep 1999
    Location
    Posts
    31
    Points
    9,248
    Level
    22
    Post
    not that easy of a fix. i had the electronics guy here at work resolder all the joints, and now it's more constant (doesn't have to get cold to make the noise, it always makes the noise!). ouch. oh well, i found a replacment amp at a great price.
    thanks guys.
  5. #5
    Achievements:
    Join Date
    Mar 2000
    Location
    Posts
    3,685
    Points
    15,556
    Level
    30
    Cool
    So, do you wanna flake off that dead amp cheap?
    LORD DUKK SAYS SO!
    The Big Show
  6. #6
    Points: 11,245, Level: 25
    Level completed: 44%, Points required for next Level: 505
    Overall activity: 28.0%
    Achievements:
    Join Date
    May 1999
    Location
    Fort Frances, Ontario, Canada
    Posts
    490
    Points
    11,245
    Level
    25
    Post
    How thourough was he when he re-soldered it. Sometimes it takes a fine tooth comb to locate a bad connection. You can't always tell by looking at them. Even loose screws which hold the pc board to the chassis of the amp can cause grounding problems. Heck there could even be a small crack on the board. Sorry Dukk, I know where you were going with that . Sounds like he re-soldered the broken connection if it's more constant, but it could be a lifted/cracked trace and he un-did it permanently.
    I'd love to have a crack at it!
    inno73@hotmail.com
  7. #7
    Achievements:
    Join Date
    Mar 2000
    Location
    Posts
    3,685
    Points
    15,556
    Level
    30
    Cool
    What? I got a couple of old school RF amps and I am always looking for matches...
    LORD DUKK SAYS SO!
    The Big Show
  8. #8
    Points: 11,710, Level: 25
    Level completed: 96%, Points required for next Level: 40
    Achievements:
    Join Date
    May 1999
    Location
    Vancouver, British Columbia, Canada \'eh
    Posts
    1,056
    Points
    11,710
    Level
    25
    Post
    Could also be a condensation problem. Corrosion will tell the tale.<CENTER>
    E.C. Wuz here
    [This message has been edited by Eli47 (edited 01-01-2000).]
  9. #9
    Achievements:
    Join Date
    May 1999
    Location
    Posts
    490
    Points
    11,245
    Level
    25
    Post
    You'd think the tech. would have found that when re-soldering.
    By the way, were you two at the same party? It looks like you both got home at the same time.
    inno73@hotmail.com
    [This message has been edited by Inno (edited 01-01-2000).]
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
