Results 1 to 5 of 5
Thread: remote
  1. #1
    Points: 9,912, Level: 23
    Level completed: 83%, Points required for next Level: 138
    Overall activity: 0%
    Achievements:
    Veteran5000 Experience Points
    Join Date
    Jun 1999
    Location
    Carriere, MS, US
    Posts
    213
    Points
    9,912
    Level
    23
    Is there ever a need for a thicker remote wire? I'm running 3 things off of it...and I'm planning running another 100 watt amp...and 2 neon lights.
    As soon as my 10's come in and i have them setup...I'll have my stereo, an eq, and a 200.2 running off the same remote wire.
    Should I add another remote wire or what? I don't know how or where to run it from if i have to add one. Should I run my neons at a constant 12v and put a switch on them. Or should I run them from the remote?
    <center></center>
    [This message has been edited by Patrick (edited 06-22-99).]
  2. #2
    Points: 15,933, Level: 30
    Level completed: 49%, Points required for next Level: 517
    Achievements:
    Veteran10000 Experience Points
    Join Date
    May 1999
    Location
    nowhere
    Posts
    3,118
    Points
    15,933
    Level
    30
    Patrick, I dont think you'll find you need a heavier remote on lead. Remote leads only close a relay or a transistor inside the amplifier or eq or whatever processor you may be running. However, if you feel the need, you could always make your remote lead close a relay that would then send power down to the amps and stuff. A relay will allow battery power to power everything after it.
    members.tripod.com/Audiophyle
    Ba Chomp, Ba Chewy Chomp, Ba Chewy Chewy CHOMP!! Someday, we'll all look back on this, laugh nervously, and change the subject!!
  3. #3
    Points: 23,721, Level: 37
    Level completed: 48%, Points required for next Level: 629
    Achievements:
    Join Date
    May 1999
    Location
    Huron,Oh
    Posts
    8,027
    Points
    23,721
    Level
    37
    Like Audiophile said..Bigger wire na...But a relay yes for sure..
    _____________________
    1999 USAC Finals Qualifier
    Usac Sactioned Judge
    -----Judged-----
    1999 Spring Break Nationals
    1999 Midwest Regional
    1983 Camaro-152dB old system..new system on the way.
    -Irc Chat Room-
    chat.talkcity.com
    ports 6667,6668,6669,7000
    Room Name #auto-audio
    I am the room coordinator for this room. Stop by sometime and say hi...We are busy after 9:00cdt usually.
  4. #4
    Points: 11,334, Level: 25
    Level completed: 54%, Points required for next Level: 416
    Achievements:
    Join Date
    May 1999
    Location
    Sugarland, Tx
    Posts
    926
    Points
    11,334
    Level
    25
    <font color="teal"><cite>Or build a real cool solid state remote
    line current amplifier. hehehhehhe
    </cite></font>
    <a href="http://www.feist.com/~mopar/" Target=new><p align="center">
    <font color="red" size=5><blink>Tech's Car</blink></font></p></a><p align="center"><font color="red" size=5>Install Upgrade Pics</font><p align="center"><font color="red" size=3>Building my doors and kicks</font><p align="center"><font color="red" size=3>My drivetrain upgrades</font>
    'Where there's a will there's a wall'
    'Would you like a little SQ with your SPL?'
  5. #5
    Points: 15,556, Level: 30
    Level completed: 11%, Points required for next Level: 894
    Achievements:
    Join Date
    Mar 2000
    Location
    Abbotsford, BC, Canada
    Posts
    3,685
    Points
    15,556
    Level
    30
    Way to keep it simple Tman!! hehe
    And that's the bottom line, cuz:
    LORD DUKK SAYS SO!
    The Big Show
    The Dukk says: Know your bass: PORT your damn box!!
    Have HoleSaw, Will Travel!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
