Page 1 of 3 123 LastLast
Results 1 to 9 of 25
Thread: Honda Prelude Door Panels
  1. #1
    XtremeHonda
    Guest
    Anyone know how I can put a 6.5 in my door without modifying it. I want to keep the stock look, I just recovered the grills with new grill cloth and I dont like to build out doors unless absolutly necessary. Any input is great thanks!
  2. #2
    Points: 15,556, Level: 30
    Level completed: 11%, Points required for next Level: 894
    Overall activity: 0%
    Achievements:
    Veteran10000 Experience Points
    Join Date
    Mar 2000
    Location
    Abbotsford, BC, Canada
    Posts
    3,685
    Points
    15,556
    Level
    30
    What year? Most 6.5s will fit in all but the oldest Preludes. The plastic cup needs to be removed, and a spacer may need to be fashioned out of wood, but all but the beefiest midbass should fit.
    And that's the bottom line, cuz:
    LORD DUKK SAYS SO!
    The Big Show
    The Dukk says: Know your bass: PORT your damn box!!
    Have HoleSaw, Will Travel!
  3. #3
    Points: 10,089, Level: 24
    Level completed: 5%, Points required for next Level: 761
    Achievements:
    Join Date
    May 1999
    Location
    Melb, Australia
    Posts
    303
    Points
    10,089
    Level
    24
    Post
    Dukk.. i know its an old post!
    i got a 90model prelude and i know about the plastic **** they speaker holds on to...
    if i make a new mounting baffle of say 12mm mdf (0.5inch), or thicker, i can see that i can mount a fairly standard 6.5 driver of say 65mm (2.6") mounting depth. BUT if i do that then the door trim will not clip back on...
    help!!
    and whats the bigger driver u've installed in a 90 prelude???
    oh, and any tips for sound deadening the doors?
    bloody preludes.... impossibly shallow doors and small boots (trunks)
    [This message has been edited by Jimbo (edited 01-09-2000).]
  4. #4
    Points: 15,933, Level: 30
    Level completed: 49%, Points required for next Level: 517
    Achievements:
    Join Date
    May 1999
    Location
    nowhere
    Posts
    3,118
    Points
    15,933
    Level
    30
    Post
    I saw a '90 'lude with 8's in the doors... and NO buildout! They did have to move the window tracks back about an inch or so.
    STILL waiting to hear a GOOD pair of HLCD's!!
    If it dont fit, force it... if it breaks, it needed to be replaced anyway...
    members.tripod.com/Audiophyle
  5. #5
    Achievements:
    Join Date
    May 1999
    Location
    Melb, Australia
    Posts
    303
    Points
    10,089
    Level
    24
    Post
    hehhe... thats alittle hard from me... though 8s would be killer!
    oh BTW its got electric windows
  6. #6
    Points: 24,279, Level: 37
    Level completed: 95%, Points required for next Level: 71
    Achievements:
    Join Date
    May 1999
    Location
    Charlotte,NC USA
    Posts
    8,055
    Points
    24,279
    Level
    37
    Post
    Put some Illusion Audio speakers in the doors- if you can get them in Austraila that is. I have their 8s in the doors of my 300ZX and they rock! The 8s are 2 1/4 inches deep, and the 6 1/2s and 5 1/4s are even more shallow. If you can't get those speakers down there, I will be more that willing to fly down to Australia to deliver them. Orion also makes a really shallow 6 anch 8 inch midbass.
  7. #7
    Points: 9,116, Level: 22
    Level completed: 84%, Points required for next Level: 134
    Achievements:
    Veteran5000 Experience Points
    Join Date
    Jan 2000
    Location
    San Jose, CA
    Posts
    76
    Points
    9,116
    Level
    22
    Cool
    I have a prelude too, an 88, and boy it rattles like a mofo!! Anyone have any tips on reducing the rattle the doors and windows make?
    As for getting 6.5's in the doors, it wouldn't be easy, but it's definitely do-able.
    2 12" punch XLC's
    punch 75.2...kenwood 846X
    punch power 250.2
    kenwood KDC-9011 head unit
    The more I learn, the more I realize how little I know!
  8. #8
    Achievements:
    Join Date
    May 1999
    Location
    Melb, Australia
    Posts
    303
    Points
    10,089
    Level
    24
    Post
    i know i can fit 6.5s.. i got 6.5inch infinity kappas... they are shallow... but i was thinking of gettting a higher end component system such as the Cantons or A/D/S's but they are both 1/2inch deeper...
    no my doors are pretty good, but of course i want to make them DEAD!
    hehhe
    someone wants to buy me a pair of illusion audios and deliever them to me! hahha free??
    naaah u cant buy Illusions or A/D/S's...
    i'm having my relatives buy them and ship them to me to OZ
  9. #9
    Achievements:
    Join Date
    May 1999
    Location
    Charlotte,NC USA
    Posts
    8,055
    Points
    24,279
    Level
    37
    Post
    Deliver free? Don't know about that one.
    Too bad you can't easily get those brands down under. And I really wanted to go until I heard that .
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
