posted
I just got my Sony CDX-C5850 HU, but I got the last one (I think they're being discontinued) and it was in the board. Since it was their demo I got 10% off but no manual. I know the gray, gray/black, green, green/black, white, white/black, purple, purple/black are the 4 speakers outs. I'm pretty sure the black is ground, yellow is switched power, and red is constant power. If any of these assumptions are wrong please let me know.
Now there is 2 blue wires, one with a white stripe. Are they both accessory power on or what? I also have a light blue wire. What the???
What is the Right way to connect these up? What kind of connecters? Soldered, Crimped? Every other install I've done has been pretty rough, I'm ready to do it right. All help is appreciated.
Posts: 2 | From: Vail, CO | Registered: Mar 2000
| IP: Logged |
posted
Hey Monk, on my Kenwood I have a pair of orange wires that arent hooked up, maybe thats the case with your extra blue wires. The light blue wire should be your remote turn on wire. Yes, black is the ground, red power. Ive found that sodder is the best, if it is available to you. Otherwise i just connected them real well together, and used electric tape(i dont recommend this though)....but get it soddered if you can.
------------------ -Steve Ignacek-
Running the "peoples subwoofer" 2 12" IDQ's Instert Amp Here
If you aint down with the iggster and his sounds I got 2 words for ya: Image Dynamics!!!
posted
I can;t say specifically ofr the Sony, but on MOST decks with 2 blue wires, one with a white tracer, the traced wire is for a power antenna (it will turn OFF when a CD is put in!!) and the other is the amp remote on.
If I want to do a real neat job, I will buy a harness adaptor, take it apart, pull the wires out of the pins and put the pins directly on the wires from the deck. With the plug reassembled you have a perfect harness with no intermediate connections.
And that's the bottom line, cuz: LORD DUKK SAYS SO!
The Big Show The Dukk says: Know your bass: PORT your damn box!! Have HoleSaw, Will Travel!
quote:Originally posted by Monk: yellow is switched power, and red is constant power.
Now there is 2 blue wires, one with a white stripe. I also have a light blue wire.
Hey, The red is switched ignition, the yellow is constant. The blue/white *should* be amp remote, but I'm not positive on that one. The blue should be power antenna lead. These two may be opposite. You've got me on the light blue one, maybe a cell phone mute or another oddity.
The best connection would be to solder. Next would be quality crimp (butt) connectors. Do not twist and tape!
------------------ Jeff President, Sweet Sounds Inc. Authorized Dealer for Cerwin Vega, Image Dynamics, Clarion Pro Audio, Stinger, Hifonics, Digital Designs, Memphis and more.....
